I'm preparing my basement grounding hookups.
In the picture, the circa 1952 house electric box is grounded to the water pipe at it's basement entrance....one wire leading from the box to the pipe.
There are two (2) old TV satellite dishes, now unused, connected to this main wire.
ALL the wires are covered in various substances: green surface corrosion, dust, dirt, white block wall waterproofing paint...at the foundation the "gap" through the block had some seepage and a previous owner filled that with gobs of expanding foam which I have chipped away revealing the buried cruddy, corroded original ground wire connection with the pipe.
Anyone have any suggestions on how/what to use to clean up this mess, prepare some CLEAN wire surface to attach antenna grounds. There remains some foam in the pipe hole...what can dissolve that to clean the pipe and original wire connection?
To the right we had a total house water shutoff valve installed whereby the plumber installed a section of plastic pipe...rendering the entire remainder of galvanized pipe feed isolated/insulated forcing me to bring antenna wires to the box vs utilize that closer to the other end of the house.
Thanks for any ideas or suggestions.
