The manual doesn't say, so I was curious how long the battery needs to charge before it's good to go. Just got my new SDS100 today.
IIRC, the figure I've seen for charging from the point where you get a low battery warning, to fully charged, is in the 8-9 hour range, using the included adapter & cable. However, with the SDS100, you can charge and scan at the same time. If not using the included adapter, your power source should be able to deliver around two amps to both charge and scan without issues. Also, be sure that you use either the original cable, or at least one capable of carrying that much current. There have been reports of the scanners 'not charging' because a cable, with too small gauge wiring, could not carry the needed charge voltage/amperage.The manual doesn't say, so I was curious how long the battery needs to charge before it's good to go. Just got my new SDS100 today.
That's a great idea. I bought mine right after it was introduced and it was "on sale" but even at $60, it a good deal for the peace of mind, if nothing else. Having said that, I still occasionally hook up the charger so I can listen and charge at the same time.Buy the charger / extra battery kit and never think about it again. Best $60 I've spent in a while. Get up in the morning and swap batteries and go.
I'm using a higher amperage charger as well. The problem with the manual, which as you note was more of a first draft, is that many of the details change after the scanner is out in general use.Hiegtx, my mention of 1 amp came out of the manual but, admittedly, it came from the first draft of the manual. I think they were saying 1 amp is the minimum for a full charge in a reasonable time. The unit comes with a 2 amp charger and I use a 3 amp charger so that I can sometimes use the radio while it's charging.
Until the LED on top of the radio goes from red to green.The manual doesn't say, so I was curious how long the battery needs to charge before it's good to go. Just got my new SDS100 today.
It uses too much power for AAs to be practical. Li-ion is the only reasonable option.It took me about 15 minutes after reading your post to decide to do just that. I hate being tied to a proprietary battery pack, but it's really the only way to go with this radio.
My wife just happened to ask me what I wanted for my birthday...![]()
Some folks don't realize how much is going on inside the SDS100. I suspect a set of AAs would only last three or four hours. Unlike many other scanners, you can safely charge the battery in the radio.
