hi, anyone know of any places that sell the older than 5 year old radio shack scanner parts? thanks for any info!
RSU # Description Sug. Retail Availability Additional Description
11318540 DIODE 1N4003A RECT SI $1.19 In Stock
10516136 XSTR 2SA1162-Y SI LOW PWR AMP $2.49 In Stock
10538411 ANTENNA RUBBER DUCKEY $10.19 In Stock
10906600 IC,AN7805 VOLT REGULATOR 5V $2.49 In Stock
10562346 COIL,LF207 SMALL CAN TYPE $2.49 In Stock ANTENNA/CENTER ADJ
10596138 RESONATOR,CERAMIC YY-1022 $3.41 In Stock
10617587 DIODE 1SS184-TE85R SI $2.87 In Stock
10625556 DIODE 1SS85 $2.87 In Stock
10681344 PLATE,SPRING KNOB $2.87 In Stock
10710747 CLIP,BELT $5.37 In Stock
10715100 HARDWARE KIT,20-305 $2.87 In Stock CONSISTS OF: SCREW P TIGHT BH D2X6 (6) SCREW PT BH D2.6X20 (4), SCREW FLAT HD M3X4 (2)
10722296 JACK,9.2 ANTENNA $5.99 In Stock JK-474BNC-RB3-8D-01 FOR ANTENNA
10731495 JACK,POWER/CHARGE $3.99 In Stock WITH BLACK CONNECTORS
10767325 KNOB,BLACK $2.49 In Stock
10787935 KEYBOARD,RUBBER KE-009 $11.11 In Stock
10801686 LCD $31.69 In Stock
10912517 IC,TK11806M BIPOL DC-DC CONVTR $6.62 In Stock 8 PIN SMD
10980175 POT,VARIABLE SQUELCH 100KC $6.62 In Stock
11134756 PCB ASSY,KEY W/LCD $35.75 In Stock
11158458 PCB ASSY,IF $28.29 In Stock
That is not true. Did you go into a store and was told this or did you call the 800 number?crippledchicken said:i checked with radio shack, and they say they only stock parts for scanners that are not older than 5 years old
yeah, doesn't make any sense. i must have talked to someone who didn't know what they were talking about like you run accross in many of the stores lol! i'll have to give it another try. thanks!Dubbin said:Well thats funny because I was able to buy parts for my PRO-43 and its much older then 5 years.
LOL You're 8 years too late. LOLBattery Holder for PRO-43 scanners is available on eBay. Radio Shack no longer carries battery holder for this scanner. This particular Battery Holder is used for about 16 Pro-Series scanners. According to Radio Shack this holder is no longer manufactured.
This is a 4AA Battery Holder. The one needed is a 6AA Battery HolderIs that the same battery holder that was used on the PRO-106 because if so, I have the black one kicking about in my spare parts bin you can have.
