TRX-1: Battery issues
Has anyone else had a problem with the TRX-1 draining the batteries when not in use?
If I have batteries in the radio, doesn't matter if it is alkaline or rechargeable or toggle switch set to NiCAD or ALK, and don't use the radio for a few days (3-5 days) the batteries are dead when I try to turn it on. I do not remember having this problem in the past, but can not remember for sure.
Any suggestions?
djeplett
NE Wisconsin
If you're using older NiMHs their internal resistance will often drain them in a short amount of time. I've had to get rid of a lot of old NiMHs because of that. Got too annoying having to recharge & then use them immediately.
Thanks, but happening with Alkaline and new set of rechargeable batteries.
