UPCoffeyvilleSubMain2
I've seen a number of posts similar to this but not identical, pardon me if this has already been addressed.
This is about the green/red/off LED on the right upper quadrant of the face.
What is being measured to effect transitioning from red to green to off etc?
The reason I ask is on my machine, the indicator frequently changes from green to red and vice versa for no apparent good reason.
In other words, if I have "charge while on" and the lower USB port is plugged with a cable supplying voltage, the light will come on either red or green.
The indicator seems to turn green when the battery is determined to be fully charged and turns red if it is not determined to be fully charged.
Here's where I'm confused: sometimes, when the LED is green and plugged into USB power (which as far as I can tell isn't interrupted), it will change to red while the voltage as displayed on the color panel is at a typical maximum (4.19 to 4.22V) .
Then after a while being red, it will go back to green again without evidence of an improved voltage.
I have also repeatedly experienced the "Low voltage on the charger" (or whatever it says) message which interrupts scanning until acknowledged, then "charge while on" has to be enabled again.
If there were one thing I'd like to see changed on this device, it would be to let it keep scanning and flash the LED red-green or something like that to signal low voltage.
Anyway, I've tried three different power sources and three different cables with this one SDS100 and it seems to all point toward a loose connection in the SDS100 between the USB port and whetever the electronic wizardry manages the power and raises the LED signals.
Any thoughts?
Any thoughts?
