Battery Question for Upman
EMS-1
West Jefferson County, Ala.
I have a BC250D Scanner that uses the BP250 Battery Pack and my question is : The Manual (which incidentally reads like a chinese typewriter) states that you have to charge the battery for so many hours and then to disconnect the Wall Plug Charger when the battery is fully charged, What I want to know is whether I can leave the Wall Wart attached while listening to the scanner without damaging the scanner because it does get quite warm after being plugged up for a while ?. Or do I have to unplug the battery pack to use the AC power adapter ?. Thanks.......Carl
UPMan
In Memoriam
Uniden Representative
Arlington, TX
Continuously leaving the charger plugged in will reduce the battery pack's useful life. It should not harm the scanner itself.
