To you battery gurus out there I have question. My issue is this. I have 4 Duracell NiMH 2650mah batteries.
After recharging the batteries in a charger, the 4 batteries placed in a Pro9X battery holder meter at 5.2VDC. When placed in any one of my Pro9X series scanners, the scanners react with either a low battery warning or do not work at all. After removing the battery holders from the scanners they still meter at 5.2VDC. I have switched between battery holders (black & yellow) with no change in behavior. I have other batteries that meter at 4.7VDC that work fine in the same scanners with the same holders. Any ideas??? Is it because there is sufficient voltage but no amperage??
B.K.
B.K.
