Battery vs AC adapter power
jimr99
Round Rock, Texas
I listen to railroads with my PRO-135 and PRO-528 and noticed that reception is much better with battery power than AC. The scanners require 9V 300 mA and I am using a Radio Shack 9V 800 mA adapter. Is there an adapter that will match the reception I get with batteries?
Thanks,
Jim
DickH
Thanks,
Jim
I haven't heard of that problem, but you are much better off to buy a good charger and extra batteries and always run on battery power. There have been dozens of posts here recommending not using the A/C adapters because sooner or later you may experience a power surge that can damage your scanner or a component can fail and damage the scanner.
The scanners will run just fine on a power supply with a higher current rating, because the scanner will draw only draw as much current as it needs. Those scanners draw only around 100 mA.
majoco
Stirrer
New Zealand
I'd be very wary of using AC adaptors (wall-warts?) for two major reasons.
1. A 9volt adaptor will be supplying 9volts at its rated output - in your case 800mA. The regulation of the tiny transformer is pretty poor, so by only drawing 300mA the output voltage could be waaay high - maybe damaging your radio by either over-stressing voltage sensitive parts, changing the operating parameters of amplifiers etc or getting the thing overheated in the voltage regulator stages.
2. A lot of power supplies are switch-mode types, which radiate high frequency noise over a wide range of frequencies. This may be overriding your incoming signal. Do you have to adjust the squelch when using the AC power supply? That's usually a clue.
kruser
West St Louis County, MO
What majoco said is very true.
The exception here is only if the wall wart is a truly regulated type that puts out a regulated voltage independant of the load placed upon it.
It the wall wart is truly a regulated type, then it is ok to use one with a higher current rating as the output voltage will always be the same. Doing this can also cure some of the noisy switching types if the orignal design was barely above the devices current requirements. A higher current regulated model will not need to work as hard.
As majoco stated, a standard unregulated wall wart depends upon a certain amount of current be drawn from them in order to bring the voltage down to an acceptable level. This is how they work by design.
I've seen many so called 12 volt wall warts that put out well over 25 volts when measured with no load. If you do not put enough load on the output, the voltage may only drop to say 18 volts which can kill things that are before any internal regulators like back lights and other components that may not be regulated internally at all.
And also as majoco said, switching type wall warts (very common these days) are notorious for emmiting RF noise. Some will completely wipe out a DSL internet signal for example. They usually do not cause many problems for a typical scanner type radio but they are well known to be bad for those into HF monitoring. Some are designed better than others also but there is no known database of ones to avoid.
I myself get rid of them and run everything I can from a bank of batteries that are constant charged from a large linear type supply. This gives me no noise from the switching type supplies plus it keeps me running when the power fails which is often here in the winter months.
I regulate my main 12 volt bank down to 9 and 5 for the devices that need those lower voltages.
For the switchers that I must keep running, I run them through an analyzer and make notes of any unwanted emmisions so I can kill them when I'm going to do any monitoring of the ranges they spew their crud within. Most all of the modern day scanners do come with switching type supplies and amazingly, the Icom R75 receiver I purchased some time back also came with a switcher supply. If I'm not mistaken, the paperwork that came with the R75 mentioned the fact that the switcher supply may interfere with certain frequencies so that was nice of Icom too mention that fact.
jimr99
Round Rock, Texas
Thanks for all the info. I have a couple sets of eneloop batteries and just bought a La Crosse BC-700 charger to take care of them. No more wall-warts.
Jim
kruser
Jim
I've had good luck with the same charger you bought. I also have the Maha one that some talk about here but I always liked the La Crosse model better.
Being that you also have two sets of batts, you should be good to go!
SlyFerret
Delaware, Ohio
I agree. I think the reduced noise that you get when you run on batteries is why you get better reception.
This is RF noise generated by the power supply, as well as just cleaner DC power feeding the radio.
-SF
james1095
Seattle, WA
Even under the best of circumstances you'll still get more noise using the AC adapter. Even if the adapter itself is electrically quiet, it will still feed noise present on the power lines into the radio.
I too have been getting Eneloop batteries and have a BC-700 charger and have been extremely happy with both. The thing I love about the charger is it will test your batteries and tell you the true mAh capacity. All of my Eneloops have always exceeded the capacity printed on the label, while just about everything else I have falls short, sometimes dramatically. Avoid all the no-name batteries, I have had especially bad experience with Tenergy cells. Yeah they're cheap, but you get what you pay for.
