baud rate for local township
njffemt08
Was emtfirebug14
hey yall. im looking for a radio that p25 for my job. i work in spotswood nj. i know we are suppose to be on a phase 2 network but i believe we are still on a phase 1 since we are still using the xts series radios. my question is how do i know what baud i need. ive spoken to my supervisor and he is not sure either most of our radios are programmed through a contract
Mr_Boh
The Land of Pleasant Living
P25 is 9600. Motorola Type II is 3600. Phase II has the same control channel as a Phase I. XTS will support both. But XTS can't due TDMA audio so the channels themselves would have to be set to fall back to FDMA.
rbrtklamp2
Dupage County, Illinois
Before you even attempt to program a radio for your your system you need to catch up on a lot of reading. If at all possible have your system admin program the radio but if you must do it your self you will need to know the band plan, site frequencies, site numbers, RFSS numbers, your authorized radio ID and most importantly have a way to obtain the system key for your trunked system. There are people on the forums such as myself that will help you as far as I can but I cannot provide a system key and that is necessary for programming a trunked radio system and if they do go phase 2 in the future you will need at the very least a APX radio with a proper flash for phase 2 TDMA. I would stick to what your dept issues you but if you really want your own radio you have a lot to consider also if encryption is used you will a need a system admin to load those keys into your radio as there is no other way to obtain them. You don't sound very familiar with programming radios and there is a lot to learn in order to do it correctly.
HTH,
Bob
Sent from my SM-N960U using Tapatalk
N4KVE
PALM BEACH, FLORIDA
Since it’s for your job, wouldn’t they give you the tools you need to properly do your job? All the years I worked in the parts department of a GM dealer, they gave me the computer work station I needed to look up parts. I didn’t have to buy my own. Wouldn’t they just hand you the radio you need for your job? Would a cop have to buy his own patrol car, & radio to do his job?
