BC-246t questions (yes more then one)
res1oz9a
Muskegon, Michigan
Ok.... I use butel's Arc246 software for scanner frequencies....
how would I go about entering a trunked system into the arc246 software or the scanner itself? like from here http://www.radioreference.com/modules.php?name=TRSDB&sid=1579
and here
http://www.radioreference.com/modules.php?name=TRSDB&sid=2209
Also when it says system type EDACS Networked which do I choose? Wide, Narrow, SCT?
:shock: :shock: :shock:
Do I make any sense? :shock:
EDIT: Ok i read the arc246 manual and figured out what i was doing wrong on the copy/paste groups things lol (guess It does help to RTFM) lol
still confused on the TT part with EDACS and networked
John_M
Rochester, N.Y.
There is no scanner capable of monitoring Edacs Provoice
(Digital). I have never programmed an Edacs system (analog) or an LTR system. Copy and Paste what you have so far programmed into Arc246
for these two systems and post it here. There are many people here who have Edacs and LTR programming experience.
res1oz9a
Muskegon, Michigan
well these are the frequencies within range of me
033 Muskegon 01 855.3125 02 856.4125 03 857.4125 04 858.4125 05 859.4625*
072 Ottawa 01 855.9125 02 858.8375 03 859.8375 04 860.8375
056 Newaygo 01 855.5625 02 857.8125 03 860.7875
026 Grand Rapids 01 855.3625 02 856.2375 03 857.3375 04 858.3375 05 859.3375 06 860.3375 (possible as i can pick up kent county)
* = frequencies in red on the page
This one is a LTR standard system
001 Muskegon 01 451.4375 02 451.8375 03 451.9125 04 452.2125 05 452.2375 06 452.2625 07 452.3125
08 452.8625 09 461.7375 10 462.0375
002 Oceana 01 451.9875 02 452.2375 03 452.4875 04 452.7375 ( I might be able to pick this up)
res1oz9a
Muskegon, Michigan
OK, I think i might be on to something....
I setup 10 systems, each with 1 frequency and 20 LCN's
like this..
Is this the right way to find stuff using LTR or is there an easier way?
slicerwizard
Toronto, Ontario
You could save a lot of time by just entering the system once (with all known frequencies, don't worry about the LCN's) and then manually monitor each channel (frequency) and see what talkgroups show up.
As you determine LCN's, just enter them.
