BC-246t : systems and frequencies
Tulsa
Is there a problem setting up 4 or 5 systems that all use the same site. All the systems would use the same frequencies, but just have different talkgroups?
The reason I would do this is because there are hundreds of talkgroups for this site, but the bc246t only allows 200 groups per site.
Zac..
LEH
Yorktown, Virginia
Not really. You can set every system up the same if you wanted. Each system is independent so one doesn't know what the other one's are doing.
Now you may need to override the 'this frequency exists' message (but I don't think so).
