BC 250 D Contol Chanel Mode
Fred1
Chester County Pa
I have a question for any other BC 250D owners. When in control chanel mode do you hear any audio from
tg ids shown, or is this function just to show you what ids are active ? I am very frustrated on using this radio. The manual is useless I think, on explaining things.
Thanks.
spooney
Indiana
If you know all the freq's in a trunk system you want to listen to I would put them all in and turn Control Channel Only OFF. Otherwise if you use Control Channel Only you will have to select the correct Plan 1-4 in order to trunk track the system.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
As stated by spooney, though if setup correctly, CC only works the same and may decode to correct VC slightly faster.
Regarding 'useless manual', under my signature click the Wiki programming shortcut for a step by step shortcut for the 250 and other scanners.
