**************** Problem Solved Thank you Signal500!******************************
I have programmed it with Butel's ARC536~pro software . it Scans fine and all
when I press (./no ) (12) ( E/Yes ) to Disable a active system it works .
however it will Not turn On a system , it says it should in the manual , just like my
396xt ??? Any help is Greatly Appreciated
