BC 785D Display Info
baddandy23
Ohio
Can somebody give me a complete description of what the 785 sill show on it's display? :?:
AZScanner
Somewhere in this room. Right now, you're very col
A picture is worth 1000 words:
As you can see, the display is still the same size as the 780 but there's 4 basic lines of info instead of all the little blips and indicators the 780 had. At first I too didn't like the display because I was so used to the 780, but the 785/796 display does grow on you after a while. I'm so used to it that the old 780 display looks too busy now. And in a mobile environment, I find the 785 display much easier to read at a glance because there's not so much to sort thru and everything is the same size.
Hope that helps... if you need more detail, I suggest visiting the 785 page on uniden.com and downloading the owner's manual - the display is covered in detail there.
-AZ
