KT4HX
I just started using my 796D and am having problems trunking two digital systems on my way to work (namely Prince William County and Fairfax County, Va). It works fine with my local analog EDACS, analog Motorola systems and conventional. When I try to track the two aforementioned systems (ID Scan), it stops on activity and displays the active talkgroup ID, but I get no audio, or at most a burst of noise or a burst of data. I went over my programming and all seems to be correct - though obviously I have something amiss. I can attach a file with my programming for those two systems later when I get home, but thought I would go ahead and post this now in case someone has any ideas of what could be causing this. I did play with the audio settings, but that had no impact. Appreciate any ideas.
