Bc-rh96
Metrofire31
Auburn-Opelika, AL
I would love to know or see how someone has successfully mounted their BC-RH96 Remote Head AND also the supporting 396/996.
af5rn
N. Tex / S. Fla
What specifically do you mean by "how"?
I've seen three. One had the head screwed to the underside of the dash and the main unit under the passenger seat. One had the head screwed to the centre console and the main unit under the back seat. The other had the head mounted into a big square hole cut into the centre console and the main unit in the trunk.
mmtstc
Ø
Minneapolis Area
I did a little bit of modification to my mounting bracket... I drilled a hole and mounted it to an L shaped Bracket that in mounted to the inside of my center console. All of the cords to the scanner were run underneath my center console to the center cabinet that my ipod cable for my head unit is also ran to. I ran a 3 port outlet DC power adapter underneath my dash and connected both the power sources for the scanner and also the power source for my scanner... Sorry about the picture quality, i had to use my cell phone because my digital camera download cable is at my house 100 miles away...
