BC125AT: BC125AT
mica5
Hello, I just got my first radio scanner yesterday, BC125AT, and this thread looks similar to the question I have.
The manual says "You could use each channel storage bank to group frequencies by department, location, area of interest, or any other way you prefer." Doesn't that mean I could save a channel to any bank I want to save it in? e.g. so I could put all the airport broadcasts in their own channel and keep them together but toggle them off them while I'm trying to listen to something else? but UPMan says "Channels 1-50, bank 1; 51-100, bank 2; etc (50 per bank).", which makes it sound like a channel is confined to a specific bank and can't be moved or saved elsewhere?
UPMan
In Memoriam
Uniden Representative
Arlington, TX
A channel is confined to its own bank. However, you can program any frequency into any channel.
dmg1969
Newport, PA
I have a BC125AT. For all intents and purposes, consider a frequency and a channel to be the same thing. You can program ONE frequency on a channel. Each bank contains 50 channels (therefore can store up to 50 frequencies).
As an example, you can program all of your aviation frequencies into one bank.
124.100 on Channel 1
118.250 on Channel 2
126.450 on Channel 3
and so on.
You can do the same with any other analog frequencies. For example, put your local fire frequencies in bank 2, police in bank 3 and so on.
Or you can do it by County, City, etc. You simply toggle the banks on and off using the numbers of the keypad.
Scan125
UK
Take a look at Scan125 Control Program. Look at the program's User Manual here:
http://nick-bailey.co.uk/scan125/Manual/Scan125-Manual.html
Buy just looking through the program's User Manual you will get a very good idea of the feature and functions of your scanner. The View/Edit Scan Banks, Search Banks and Services Banks will help explain a lot for you.
