With CC Only, you have less work to do and if new voice channels are added to the system, the scanner will automatically tune to them.
On the other hand, if you program all of the system frequencies and turn off CC Only, the scanner is less likely to act on false decodes (the Unidens do that a lot under the right conditions)
