BC246T Gets Even Better!
Uniden has released firmware version 2.05.01 for our hugely successful BC246T Compact Trunking Scanner. This firmware release includes major enhancements to the BC246T’s operation. We continue to listen to our customers for ideas on how to improve our current and future product line-up. This update:
- Improves Trunked System Scanning Speed – shortens the time the scanner dwells on a trunked system. Now, if no control channel signal is present the BC246T moves on to the next system immediately.
- Adds UHF TV Screen – automatically screens out TV station transmissions during Close Call and search operation.
- Allows Multiple CTCSS/DCS Auto Store – if the scanner detects different CTCSS or DCS on the same operating frequency during auto store, it stores the hits in separate channels, capturing all the variations being used in your area.
- Updates to preprogrammed systems – brings the preloaded systems up-to-date based on the latest data available.
- Adds Frequency Step option for Trunked Systems – allowing you to enter the exact frequency even for systems that use frequency spacing other than the scanner’s default step.
- Increases Close Call Pause to 10 seconds – making it easier to capture hits from nearby transmitters.
- Adds the CTCSS/DCS setting to the default channel name
- Changes the “All Locked” error message to “Nothing to Scan” to clarify the actual fault condition.
- Changes the Data Skip default to Off.
- Improves I-Call Lockout – now, if you use the i-Call wildcard (i0), when you press lockout, only the current i-call is locked out, not the wildcard.
- Improves CTCSS/DCS Detection during Autostore
- Fixes “Clear All L/O ID’s” bug – scanner no longer reboots if you clear L/O ID’s with more than 11 ID’s locked out.
- Fixes Close Call w/Repeater Find bug – scanner now saves the correct CTCSS/DCS and modulation settings.
- Fixes Weather Alert bug – scanner now unmutes audio after a weather alert if you press SCAN or HOLD during the alert.
- Fixes Weather Scan bug – scanner now unmutes audio if, while in Weather Scan mode you press F+SCAN for quick search mode.
- Fixes SCAT display bug – scanner now displays the frequency on the 2nd line of the display while receiving voice on a SCAT system.
- Improves Close Call/Weather Priority operation – scanner now performs Close Call and Weather Priority checks even if it is receiving only the control channel on and EDACS system or receiving voice on a SCAT system.
- Improves memory erase time
- Improves ESD tolerance
