BC246T (or BC250D) vs. Pro-96?
Which is the scanner of choice, BC250D or Pro-96?
  • BC250D
    Votes: 0 0.0%
  • other model - please post reply to thread
    Votes: 0 0.0%
  • Total voters
villadrive
Anyone who owns both of these scanners only need reply;
If you could only have 1 of them, which would you choose?
And...
Why?
JamesO
McLean, VA
Which scanner
I have a PRO-96, 296-D and 785-D. I prefer the PRO-96 over the 296-D due to the audio quality, I assume the 250-D is not any better than the 296-D? It is very hard to understand the digital transmissions on the 296-D. The 785-D is better than the 296-D but not by much, probably due to the bigger speaker and more powerful audio amp??
Uniden really did not do a good job equalizing and matching the digital audio on their scanners.
YMMV, just my opinion!
JamesO
CORN
Nashville, TN
I would pick my 296d because of the milair band. I do have both units though. They both serve a purpose oneway or another.
OmensEdge
Southwest Michigan
I've had both. Like Dubbin said, the Pro-95 scans the 9600 Baud systems. I had to sell my BC250D because the police in my area could not be picked up on it. Buy the Pro-96 and be able to listen to everything.
RolnCode3
Sacramento/Bay Area, CA
I have the -96 and a BC785 (250 in a different shell). Things I like about the -96 are obviously it does more digital. It also has the V-folders and a LOT more talk groups per bank. It has fewer frequencies however. It's a trade off. I'd gladly get my 100 freqs back, and give up 2 V-folders or something.
Things I like about the Unidens, however, are the longer alpha tags (16 vs. 12 on -96). I like that while scanning, the Uniden shows when it locks on the TRS, and then goes back to conventional. The -96 makes no indication when it's on the TRS vs. conventional freqs. It's also much easier to scroll thru and listen to talkgroups on the Unidens. In order to listen to a talkgroup on the -96, you have to go back into trunking ID hold. Would be nice if that wasn't so.
I haven't been able to find an adjustable delay on the -96, but I didn't RTFM very thorougly, admittedly. I also wish there was a way to switch between CTCSS/DCS usage and search, like on the Uniden. Only way I see to do so on the -96 is to delete the tone data. Once again, though, didn't RTFM, so not 100%.
Personally, I think I'd take the Unidens, even though the -96 has a lot of strong selling points/cool features.
OmensEdge
Southwest Michigan
I also think I'll add that the BC250D rechargeable battery performance is poor compared to the Pro-96. I remember charging the 250D for about 6 hours the first day I received it and I got about 3-4 hours listening before it needed to be charged again. I get a little bit more than twice that amount on the Pro-96 with the RS Ni-Cad batteries.
astrodanco
"Down San Diego way."
Do yourself a favor and go to Target or Walmart and purchase some $9.99 four packs of 2500mah AA size NIMH batteries. Slow charge them overnight for maximum life. Your PRO-96 will love you.
OmensEdge
Southwest Michigan
Alright, cool. Do you need to have a special charger to charge them or can I just charge them in my radio like I do the others?
astrodanco
They're just 2500mah NIMH batteries like any other 2500mah NIMH batteries, so you can certainly charge them in the radio if you want to. Even though I keep my PRO-96 on external power whenever I can, I also have several sets that I keep charged via an external charger. I gather the PRO-96 is also charging the batteries currently in the set whenever it's on external power. I'm not sure if I like that. Does it have a smart charger in there? If not, perhaps I should put the NIHM batteries in the Alkaline battery holder so that they don't get charged while in the PRO-96.
villadrive
I bough the Pro-96 today!
Hi All,
Your input and guidance assured me that the Pro-96 was right for my needs. I live in the Bay Area and having a versatile and digital capable scanner was important. Along with the excellent deal at Radio Shack for $399, I could not pass it up. They programmed my local freq's in for me at the store and it is great.
It will take me a few weeks to learn all the terminology related to digi scanning as well as regualr, but all of you were SO helpful and no one was extreme or radical.
I like you guys! Good friends ot have around!
Ciao!
TAZ :lol:
OmensEdge
Southwest Michigan
Thanks for the info, man!
And villadrive, congratulations on your purchase.
