BC246T Rebanding Update Available (v2.60.00)
MarkWestin
Caribou, Maine
Install_BC_VUP_v2.0.0.6.exe
I'm having an odd problem. I downloaded the updater and the firmware from the links in your mediawiki page. When I try to install the updater, it installs version 2.0.0.3. I searched my system and deleted the .msi file for the version 2.0.0.3 installer, but the "2.0.0.6" installer actually installs 2.0.0.3. (?) I'm not sure how to proceed.
UPMan
In Memoriam
Arlington, TX
Hmmm. I don't know what would cause that, either. However, the update is installable with 2.0.0.3, too.
UPDATE
Make sure you delete any copies of the "BCSS" directory before installing. In some cases, the computer will use an old copy of the installer if that directory is there.
ME343
ME/NH/VT DB Admin
Gorham, ME
Upman i am looking and it only shows DND and the rabanding support but nothing about the
RSSI Reporting Improvements. Is that included but not listed
UPMan
In Memoriam
Arlington, TX
It is listed and included. There are no instructions for RSSI (it just improves an existing function).
UPDATE
Sorry, I got my threads confused. RSSI improvement is not included in this update (the BC246T's hardware doesn't support it). That is why it isn't in the release notes.
KE4ZNR
Radio Geek
Update applied to my 246t...no issues and it was very easy :cool:
Marshall KE4ZNR
UPMan
In Memoriam
Arlington, TX
Well, color me confused. There are no references to RSSI in either the BC246T update 2.60 release notes or the BC246T serial protocol reference.
Sorry, Slicer, I had my threads confused. I've amended my previous answer...no RSSI in the BC246T (the hardware doesn't support it).
peepoop
Premium Member
Went smoothly for me.
The copyright notice on bootup still says 2004 though.
UPMan
In Memoriam
Arlington, TX
Most of the code is from 2004...so we can claim copyright protection back to then.
For developers, I just attached the revised Remote Control spec to the release notes.
ME343
ME/NH/VT DB Admin
Gorham, ME
thanks Upman for the info but how come it said it was included in the email sent back in august
CLTX11
North Tx
Got everything squared away as well without any problems.
Yes the DND CC is something that will help out, I hated using CC-Scan because you would miss address's etc.
Thanks for the heads up on the update!
w9zro
NWI
is it normal to have to delete and reprogram a system to take the custom tables or can you just modify it??? Askin cause I really dont want to enter everything by hand AGAIN :D:D:D:D
thanks in advance
W9ZRO
