BC246t
Sigsguy
Good day all,
Just curious as to where I may find dbase frequency files to upload in the BC246t scanner of the Ottawa
area. Is there a area where people post their files for sharing?
CLTX11
North Tx
captclint
Mountaintop, PA
area.
If you become a paid subscriber to this site you can get the automatic down loads, which is often better than someone else's file. This is also very reasonable($7.5 for 3 months), and can save you countless hours of programming and frustration.
To take advantage of the automatic downloads, you will need some software: http://wiki.radioreference.com/index.php/BC246T#Supporting_Software Three that provide the most value are ARC246 by BuTel, and free programs, FreeSCAN and BCtool. They allow a automatic download of any or all frequencies in your area, and sets up trunking TGID's & para's(this is a big help). They have a neat virtual control panel that works your scanner from the keyboard., but the best part is that it logs all the information(freq & PL) and lets you see your scanner window in a much larger scale that you can actually see clearly. The logging is great when searching, but it is also handy for normal scanning. Often, I do not look up in time to see what agency was just talking, so I just look at the log.
Neither BCtool or FreeSCAN work well with the 246 logging, so if that is something think you would like, then I can strongly recommend ACR246. If logging is not needed, then I lean towards BCtool, because the display can be easily minimized and made to "stay on top". However, you can download all three and see which one you like(ARC free demo has some limitations, but it is robust)
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
While it doesn't have the ability to connect to the database as the other 3 packages Clint mentions, Scan Control does work with the 246; I haven't heard of any logging issues with this radio. The URL is here, and it has its own Yahoo group for support
Instead it has a copy/paste utility set up for the database which is a bit quirky, but does work. I don't particularly like the editor, but it too works. Worth checking out. It too has a demo that, I think, limits you to 3 systems' worth of programming, but that's enough to evaluate it.
Although using others' files has its pitfalls, it's certainly a valid way to get started. There are 2 fairly active Ontario Yahoo scanning groups - Scanont and OntScan; a Yahoo group for the 246 and even a 246 dedicated webpage. All of them may have what are known as UASD (or Uniden Advanced System Director) files, which can be imported for use. Here are a few URLs...
http://groups.yahoo.com/group/Ontscan/
http://groups.yahoo.com/group/scanont/
http://tech.groups.yahoo.com/group/arc246t/
http://groups.yahoo.com/group/BC246T/
73 Mike
slicerwizard
Toronto, Ontario
Ontscan? Here's a typical posting - "Marlie Moore and Morgan Dayne perform some amazing erotic twisted positions and balancing acts on a stairwell banister as they get crazy with their lovemaking..."
Sounds like a real swinging group!
DaveH
Ottawa, Ont.
Good day all,
Sort of ambiguous, do you mean Ottawa Ontario, Ottawa Kansas or ...?
Dave
torontokris
Toronto Canada
Dont use the ONTSCAN its all spam messages now.
Use SCANONT or the EASTERNONTARIO group is pretty good.
thats assuming its Ottawa Ontario
