BC250D problem on MECA I
FD_1226
I have a BC250D and I have it on MECA all day usally and around midnight I loose a signal conpletely. I have to turn the scanner off and back on to regain a signal.
And this happens just about every night around midnight. Anythoughts?
scannerfreak
Well Known Member
Indiana
Control Channel Change? Maybe the scanner isn't seeing the new control channel and it needs to be re-booted?
scannerfreak
Well Known Member
Indiana
BPJackson12 said:
Is this when the Control Channel changes?
Generally, but I do not know this for sure with MECA..Just keep an eye on it and see if this is when it changes..The scanner should find it..but maybe there is something wrong with yours..
fire4456
Indianapolis, IN
the control channel changes around midnight or so i believe. this is similar to their system-2 which is the public works system.
FD_1226
That has to be what it is becasue i've been checking and right at or after midnight i loose the signal.
