BC296D is trunking working?
dlbrock
Russiaville, IN
I am new to digital scanners and just purchased the BC296D scanner. At this point I am not convienced that the trunking function is working. Using the Uniden provide scanner software and an ascii import file taken from
http://www.bearcat1.com/fleetin.htm I was able to get up and running rather quickly but I am noticing that I am not hearing both sides of the conversation. That makes me think the trunking function is not working.
I live in Indiana and they use the G.E. Ericsson system. I am not sure if it's wide, narrow, or scat but I have tried all three with what appears as no luck. After spending several hours in this forum reading, I decided to purchase the ARC250 Basic software. I downloaded bank #1 and immediately noticed that the eight LCN channels were not 'trunk' enabled. Even though the bank was in the scanner interface. I enabled trunking on each LCN channel and uploaded everything back to the scanner. After doing this the only way I could get any hits was to select the 'Trunk' button and then manually switch between the LCN channels and then conversations appeared to be broken like before. I have since turned off each LCN channel for 'trunking' and the bank is still enabled but I am not convinced I have everything setup correctly.
If anyone is an expert with this scanner I would really appreciate some advice.
Thanks in advance,
Doug
mciupa
Canadian DB Admin
Moderator
I'm here a lot
dlbrock said:
Using the Uniden provide scanner software and an ascii import file taken from http://www.bearcat1.com/fleetin.htm I was able to get up and running rather quickly but I am noticing that I am not hearing both sides of the conversation.
No kidding , that ascii file is horribly inaccurate and out of date. No
wonder you are receiving missing tx's.Your scanner is doing the best job with the info it was given.
The best resource is right here at Radioreference.
I checked your post history and found that you are interested in this location.
Use this link to program your scanner.
http://72.3.135.37/modules.php?name=TRSDB&sid=952
Good Luck !
JoeyC
Senior Member
San Diego, CA
I can assure you the 296 trunks perfectly (and I don't even own one) Do as mciupa suggests and provide the proper information to the scanner before you give up on it by using the information on RR. bearcat1.com is a joke.
dlbrock
Russiaville, IN
I used the reference mciupa pointed me to and everything is working now. I think I will write a beginner's guide to the 296D and post it on this forum. Just the down and dirty, how do I do it and nothing more.
Thank you everyone for your help. It's amazing we used to get along without forums like this! :D
loumaag
Silent Key - Aug 2014
Katy, TX
We would pefer that such things be posted on the Wiki, as it really isn't a discussion item. 8)
loumaag
Katy, TX
dlbrock said:
Ok, can do. What and where is the wiki?
You can link to it from the home page of the site. Everything is explained there.
