BC296D LTR Scan/Search
DaveIN
Founders Curmudgen
West Michigan
Ok, how do I get the search feature to work with a regular LTR system?
I have eight frequencies in trunked mode L in the correct LCN's.
All I am able to do is scan. Scan shows saved or new talkgroups, but I was thinking it should be in a search mode.
Any ideas?
mr_hankey
Helotes, TX
this is a pain with the Uniden 250/296.
you will either have to 1) wait until an LTR id comes up and then either press SEARCH or SCAN or 2) program a motorola or edacs system in another bank and jump over to it to MAKE SURE you are really in SEARCH mode on the LTR bank
the second suggestion comes from not knowing whethere you are in SEARCH or SCAN mode with the 296 while tracking an LTR bank - there appears to be no other way to tell!
DaveIN
Founders Curmudgen
West Michigan
I can see that my Motorola system is in Id search mode, but when I press search in the LTR bank it starts searching in my saved search (limit) even if I select channel or search rotory mode. It acts like I am in conventional mode, but the channels say L and it is in trunked mode. Did I miss something during programming? I do see LTR talkgroups.
mr_hankey
Helotes, TX
that's what i mean - you must WAIT until an LTR id comes up and is active (hear them talking on it) before you can press search or scan.
like i said, it can be a pain when you're in a hurry...
when you say "I can see LTR talkgroups" i think you're seeing the ones through the "Activity ID" feature of the 296 - it will show other active ID's that you may not be monitoring at the moment or are locked out.
i think there is one other way to get in the LTR scan lists - you have to use the MENU button, and navigate a bit, but it will only show you ID's that you can lock out and (i think) let you select a scan list to watch in SCAN mode...
but to actually SEARCH or SCAN and have it understood as an LTR command by the 296, you have to wait until an ID becomes active.
DaveIN
Founders Curmudgen
West Michigan
Ok, I'll wait for an active talkgroup and try it. I'll also try turning of the activity Id.
So much more frendly with the PRO-92. Too bad GRE dropped LTR in the newer models. Just another good reason to keep the PRO-92 around.
mr_hankey
Helotes, TX
i agree (about the PRO-92).
however, realize that LTR Regular radio systems are slowly migrating to LTR Passport and related (NET/Multi-NET) since they offer more features...
even a PRO-92"a" can't tune that...
i am of the opinion that Uniden and GRE need to take another look at LTR protocols for their next scanners...
mdulrich
Van Wert, Ohio
If you can see that is it in ID Search Mode on a Motorola or EDACS system it is in search mode on the LTR since ID Search and ID Scan are universal across all banks.
Mike
