My trusty BC296D seems to have stopped working, so I am hoping that someone may have a solution, aside from having to replace it.
I don't know if anyone has access to a service manual, or for that matter whether Uniden offers any type ot repair service for non-production models. (I'm keeping in mind that if they do I'd need to determine their cost since I don't want to pay more for a repair than what a later generation scanner might run!)
I cleared the memory with the 2-9-Manual reset option and reprogrammed it with known working sites, including VHF, UFH and the 800 band -- but same results.
I suspect that it is in the antenna connection, either a defective BNC plug or bad/broken solder connection internally. When I tune to area FM broadcast stations I can get a faint signal, so I had a friend who is a ham bring over his portable unit. I entered his transmit frequency into a open channel and when he keyed his unit I received the signal quite clearly, but then again we were only about 6 feet apart. That leads me to believe that the scanner probably doesn't have any major circuit issues.
Any thoughts, suggestions, sources for service manuals, ideas, etc. ????
Bill
Bill
