Does the bc296d use the same cable as the bcd396t to program it?
scanner99 Member Premium Subscriber Joined Aug 25, 2008 Messages 8 Reaction score 0 Location Los angeles Feb 15, 2009 #1 Does the bc296d use the same cable as the bcd396t to program it?
davidmc36 Member Premium Subscriber Joined Nov 14, 2004 Messages 1,861 Reaction score 3 Location South East Ontario Feb 15, 2009 #2 scanner99 said: Does the bc296d use the same cable as the bcd396t to program it? Click to expand... The plug on the 296 and the 396 are different but if you have a serial to usb converter it would accept the DB9 cable from either scanner. This will only work with the scanners listed. It has the converter built into it. USB1 USB Cable for Programming Uniden – Canada Last edited: Feb 15, 2009
