BC296d - what to do with it?
kc2kth
Toms River NJ
So I'm looking at my BC296d and wondering what to do with it. I always had an issue with it mainly due to charging. as I recall it needed around 14 hours charge for less than 8 hours use. Was there ever a better charging method for these? Maybe a question like this belongs in a different forum. if so, please feel free to move it.
Kingmobileaudio
Lincoln, NE
If it uses AAs get a energizer rapid charger and there AAs. Charged in 15 min
Sent from my SM-N900V using Tapatalk
teufler
ST PETERS, MISSOURI
a new battery cluster helps some but 8 hours is about normal. Shutting off the light helps some too. I left mine plugged in all the time, finally just unplugged the battery and left on the wall wart. Kept from over charging the batteries. I did find a source for the cluster, they claimed 2200 mah batteries, they were green, they did give longer life.
kc2kth
Toms River NJ
Thanks teufler, the issue with the larger pack though is even longer charge times since if I recall correctly the charging circuit was fixed at a specific, relatively low rate. This one might headed for the classifieds.
mule1075
Washington Pennsylvania
Take out the battery plug it in and use it as a base station.Also could use it as a secondary weather alert receiver if need be.
Sent from my Z750C using Tapatalk
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Put a good antenna on it and do milair. It's quite likely you've got a fair amount of it around you with McGuire just a hop, skip and jump from you...we have freqs in both our database and wiki.
Another possibility, if you're close enough to the ocean, is marine. And if that does interest you, go a bit further, mod the radio with a discriminator tap, and check out AIS monitoring. We have stuff in the wiki on that subject, too...
Mike
