banjoman
I have found that my BC346XT's speaker is going strangely silent on me on a pretty regular basis. This is often happening after disconnecting the scanner from an external speaker which I tend to use a couple of in different spots. It can stay that way for a long time and then may mysteriously start working again after being plugged in to an external so that I can listen. I have been looking through the expanded guide but can't seem to find anything about a mute button I may be inadvertently hitting. Could this be a problem with the scanner itself or would it be operator failure somehow?
Also... This scanner should need a mono to stereo adapter for stereo speakers, correct? One channel of stereo is not working but would assume that it is only a mono out.
