bc355n can I reset/remove a channel?
glennimages
Forked River, NJ
while programming the PRIVATE bank,...i started heading toward a freq i wanted, somehow I wound up programming a random freq as CHAN 2. I would like to figure out how to correct it and get the use of CHANNEL 2 again.
press prog, press private, using the up/down buttons find channel 2. hold down the L/O button about 2 seconds until its removed
dmg1969
Newport, PA
Another method is to search for the frequency that you want to be in CH2. When you find it, press Program, then Private. Now press the Up or Down arrows until you get to CH2 and press Program again. It will overwrite whatever you already have programmed in CH2. Done.
