BC365CRS VS. BCD436HP
Hello. I currently own a BCD436HP and am adding a BC365CRS to that. My question is does the BC365CRS get clearer transmissions from further away and how many miles as the crow flies does the BC365CRS pick up clearly? Thanks for any help!
jonwienke
More Info Coming Soon!
VA
The CRS probably won't do noticeably better than the 436, at least when both are fed from the same antenna. Reception range varies far more based on antenna type and location and terrain than radio specs.
Thanks. I was just using the antenna that came with the scanner.
torontokris
Toronto Canada
The BC365CRS is a non trunking, non digital, non 800mhz scanner, so if the things you are listening to are any of those the 436 will definitely pick up way more. However there maybe some freq that the 365 does better.
As mentioned the Antenna can make a huge difference.
georgesharpe
Regina, SK, CANADA
In 2010, I bought a CRS 370 from a Jewish chap in CA. Great fellow to deal with, unfortunately he passed away from Cancer late that year, and since then I've yet to see ANY dealer as prompt and courteous as he was. I have that radio, now, and it gets AM, FMB and all bands including 800 band, however it had a loose squelch and Air band was awful. I have it on hand for a trade for a super reception antenna ($20 Cdn) or I might just keep it?
2IR473
I own 2 BC365CRS radios (got one for free, and the other was only $74). I would say they are not more sensitive than my BC996P2 radios (don’t own a 436 so can’t give a comparison to it’s sensitivity), so I would not expect strong signals from farther distances.
The audio isn’t “clearer” than the more expensive scanner, and of course the 365 doesn’t receive the AM broadcast band as the earlier 370 model did. On the air band, it is on par with my 996P2. I don’t have any squelch issues with additional noise on AM receive versus FM. I do have a higher incidence of intermod interference on the 365, even with a Par 152 mHz notch filter in line, so it‘s rejection is not as good as the more expensive scanners.
I think in this case, you get what you pay for...a modest analog scanner that works as expected for the price, and has a kind-of clock radio built in. But it certainly doesn’t do anything better than my 996P2 scanners, and it is about on par with my 30 year old Bearcat 300 scanners (which have been recapped and had receiver alignments). Interestingly, my old scanners (Bearcat 300 and Bearcat 210XLT) are more sensitive on VHF low band receive than the modern scanners, but that is due to the broadband RX of new scanners (with the emphasis on 800 mHz receive no doubt).
