Kennrth
I bought a BCD996XT but ;
I would like to investigate and discuss the possibilities of upgrading the firmware in the BC785D. I like this radio.
First it would be nice to know what IC the firmware is embedded in?
Is it surface mounted?
Does it have a DIP cousin and socket for a development system that can download it and reverse engineer it?
Would Uniden be willing to sell IC’s with updated firmware?
Or sell the source code for modification?
To keep the radio current. A chip replacement would do the trick. I suspect the firmware may be in the CPU IC. This I could replace but most people may not be able to do this if it is surface mounted. And may not be profitable for Uniden to support a replacement program. But selling an upgraded IC without warrantee could do the trick. And would be profitable for Uniden.
Otherwise it will go up for sale on Ebay. That will be one radio sale the scanner makers won’t be making.
How many people would be willing to pay for a upgraded IC and could install it or know somebody who can. Keep in mind it would probably take someone with large IC surface mounting skill.
How much would you pay for the IC.
How much would you pay to put it in.
Would you risk the 10% possibility your radio may no longer work because of electrical solder damage and ESD problems and faulty IC’s.
How much is do you think the radio is worth?
How much will it be worth with as new rebanding IC is installed?
