BC75XLT(Part2)
Chris516
Gaithersburg, MD
It wants me to use Com Port 3, to read/write to/from Scanner/PC. It is listed in the Device Manager on Com Port 3. But when I try to read/write from/to the Scanner/PC. It says "No response from Scanner".
I have no problem getting local EMS calls.
wtp
Port Charlotte FL
what are you trying to program
the radio has no alpha tags, so it is just put in the frequency and you are done.
yes, computers are nice, but not necessary.
sallen07
Rochester, NY
Two questions for you:
1) Did you install the driver for the scanner cable? if not, go here:
Uniden BC75XLT Scanner
In may cases the various scanner programming software will show you devices other than the scanner you are looking for; that may be what is going on here.
2) If you *did* install the driver, is your scanner on while you are trying to program it?
Chris516
Gaithersburg, MD
At first, that makes sense. As to actual necessity of doing it by computer, instead of by hand. But then, why would there be USB drivers for it.
1. Are you referring to the USB cable that came with the scanner, yes; If you are referring to the device driver, yes. It is listed both, in the Device Manager, and in 'Printers and Other Devices'.
2. Yes, The scanner is on, when I try to program it via the computer.
Chris516
Gaithersburg, MD
IT FINALLY WORKED!!!!!!!
So as not to erase any pre-programmed frequencies. I read all the frequencies from the scanner, to the computer!!
