BC780XLT audio hum
musicman
Roanoke, VA
When I tried to use the 780 as a wireless microphone receiver, I could not get rid of the hum when I patched it into a portable p.a. system. The hum persisted even through a high-Z to low-Z transformer and a direct box, and it did not matter whether I used the tape jack or the speaker jack. The sound from the 780 speaker was clear and hum-free. Any ideas?
musicman
Roanoke, VA
780 Hum
2 separate portable PA mixer amps, a Carvin and another brand. Hum pick up on both of them.
n4yek
Cosby, Tennessee
Could try grounding the chassis of the 780 to the Mixer. There might
be a differance in ground potential there.
Also you might have a 'ground loop' which can be a bit hard to
find. If this is the case you could try to remove the ground from
the patch cord between the 780 and the mixer.
Just some thoughts to try. :)
Danny
N4YEK
musicman
Roanoke, VA
Thanks!
Since my 780-to-P.A. troubles, I have run into a separate ground loop hum problem at home. This Radio Shack adapter looks like just what I need. Thanks for the tip!
