After adding Cali Hwy Patrol into my new BCT15X I noticed I wasn't hearing anything. The CHP operates in the low 40 MHz range, FM modulation with CTCSS (see Department of the Highway Patrol (CHP) Scanner Frequencies and Radio Frequency Reference). Getting the CHP on my 780XLT has always been a bit low in terms of S/N quality from my house but definitely good enough that the speech was understandable. It doesn't seem to be a selectivity issue per se, since I get "clean" static with the squelch down on either radio.
I thought I had mis-programmed the BCT15X at first (see my previous thread
) but it just seems like its sensitivity in this band is not as good as my 780XLT. I have them sitting about a foot apart on the same table, set to a custom search and then held on 42.4400 MHz (with FM modulation set); the 780XLT can clearly pull in the transmission and speech quality is fair. Meanwhile, the 15X is just mired down in static, speech barely intelligible.
I tried switching their antennas so that now the BCT15X is using the stock supplied antenna and now it's doing slightly better than the common Radio Shack sourced center-loaded telescoping antenna, but still not able to pick out a clear signal on the same frequency. It will at least break squelch with the value set at "01" so that's a good sign, I guess.
Please note this isn't a complaint, just an observation. Fwiw, I plan on dusting off the Diamond D130J antenna I bought years ago but never installed on the roof (yeah I know!) so I hope that will improve things. Otherwise, I guess this is why people keep their older radios around eh? I have heard that the 780XLT is known for its receive quality for the aircraft bands, this might be another example of where it shines.
I'd like to hear others' stories of two radios, one shack...where one radio definitely is the better of the two at receiving a particular band.
