BC785: How do you open it up safely ???
Archie
Yonkers, NY
I need to fix my wobbling antenna jack and was advised to open up the scanner and tighten the antenna jack nut which is loose. Do you just unscrew all four screws on both sides, or just the two upper ones on each side? What about the two screws located at the antenna jack? I am an able handyman but don't want to break anything !!!
Thank You Much
kingpin
Trailer Park Supervisor
Seattle, WA
Just unscrew the for screw on each side. WHen removing the side with the speaker, take care as the harness is short. Just unlug the connector with some needlenose and you'll have it apart.
