K
kb0nly
Guest
Ok, let me first tell you how its setup...
Bank 1 Conventional
Bank 2 Trunking
Bank 3 Trunking
Let's say its scanning, doing ID Scan on the two trunking banks. When its scanning on Bank 1 and i decide to shut off Bank 1 i tap the number 1 key and now its just scanning Banks 2 & 3..
Problem is, how the heck do i now turn Bank 1 back on as the scanner now never shows the active bank list it just shows the Scanlist's for each of the trunking banks.
The only way i have found to do this is run ARC250, go to the virtual control, the scan tab, and then turn off the scan on the scanner, then double click on Bank 1 to turn it back on, and then turn on scan again.
How do you set the active banks on the scanner in this situation without having to use the computer??
I went through the manual a half dozen times and can't find any explanation.
Bank 1 Conventional
Bank 2 Trunking
Bank 3 Trunking
