bc785D & O.P.P.
b_lasalle
Brantford, Ontario
I turned on my 785D yesturday and when i triied to listen to the OPP all i got was the digital transmission noise, when they were talking, the ambulance and MTO were comming in normal. OPP were ok to listen to sat, but when i turned on scanner again today they were digital again, has something changed? i checked everything programed into the scanner and it looks just fine.
VE3JSO
sarnia ont
opp is working for me ok i suggest if you have a back up somewhere just reload it to the scanner in case you missed something
torontokris
Toronto Canada
bad signal perhaps?
as mentioned try and reload the scanner with previous known working settings incase something was hit accidentally.
If still nothing then maybe the card went bad/not connected/not enabled etc
When it boots up does it does it say something like DIGITAL CARD INSTALLED?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Those old digital cards were known to become flaky. Sometimes pulling them out and reinserting them did the trick.
