BC785D ?
hiegtx
Dallas, TX
Can you use a BC785D to monitor the Mass SP trunking system?
I'm presuming you are referring to one that has an installed, and working, APCO P25 digital card.
For the older Motorola Type II system, that's going to depend on the site you are trying to hear. The 785D cannot be updated for the custom tabled required for some rebanded frequencies. The key is the number in the fourth decimal place. If that is a 5 (five) for all system frequencies, i.e. 856.73750, then the scanner would work. If that digit for any of the frequencies is a 0 (zero), then the scanner will not correctly track that site,
Your location is indicated as in Essex County. For the site in your county:
Ayers Hill Essex 851.20000 851.37500 852.31250 853.47500c 853.63750c
Three of the five frequencies have a zero in that fourth decimal place, so the BC758D would not correctly track the system.
If you are thinking of the newer, Phase I P25 system, Commonwealth Of Massachusetts (Project 25) System Trunking System, Statewide, Massachusetts - Scanner Frequencies, the scanner cannot track that system at all. It cannot process the 9600 baud control channel data stream used on the Phase I system, though it can handle the 3600 baud used on Motorola Type II systems, providing no custom band plan is needed.
garys
Eastern MA
Yes. The exception would be the P25 system in western MA. You'd need a BC796D for that. If you're listening up in Essex County, you should be fine. The bonus would be that you could listen to New Hampshire systems that are P25 conventional (non trunking) as well.
garys
Eastern MA
He'll be fine. The Haverhill site is a fill in site, the main Troop A/H sites don't even need a custom band plan for rebanding.
For now the P25 system is limited to the western part of the state and even there the analog system is still in operation. At some point the entire system will be P25, but that's years away right now.
