BC796 Trucking ?Newbie
mciupa
Canadian DB Admin
Moderator
I'm here a lot
carsonbm, please call it trunking and not trucking!
Anyways, what is it exactly you are trying to set up? E.g. Which system(s)
are you interested in, then we can take it from there. :wink:
LarrySC
Greenville, SC
You need to research the system for your area on this web site. You should be able to find the information you need. If not, then post your location on the STATE forum requesting help. Then shop for software. Trying to manual PGM one of these scanners is a hard way to go. Good Luck
AZScanner
Somewhere in this room. Right now, you're very col
carsonbm said:
Motorola II. :evil:
Everything on this scanner is menu driven. SO, (this is from memory - the scanner's at home right now, so bear with me)
1. Press Menu
2. Select "SCAN OPTION" and press E (E selects each menu choice)
3. Select "TRUNK:
4. Select the bank you are setting up.
5. Select "TRUNK TYPE:"
6. Select the type of bank you are programming, in this case "TYPE2/P25 800" (or 900, if it's in the 900 band).
7. Select TRUNK CHANNEL
8. Select the channel you want to program.
9. Enter the frequency.
10. Enter the Alpha Tag (if desired, or press E for none)
Repeat 8-10 for each frequency you are programming, then select "DONE".
11. Select "TALKGROUP"
12. Select the talkgroup slot to program
13. Select "ID:"
14. Enter the ID you want to program
15. If desired, select "Alpha Tag" and program that as before.
Repeat 12-15 for each talkgroup.
Now you should be able to start scanning that bank and admiring your handiwork!
HTH's
-AZ
Julian1
Fresno, TX
Trunking
8)
Software. I use ARC250 which supports 250-D, 785-D, & 796-D.
That will enable you to program without all the button pushing.
I've done both........software is the way to go.
Butel is the creator of ARC250. It is available for sale on line at www.scannermaster.com . You can order a CD version or download version.
Good luck and take care!
Julian1
Fresno, TX
Trunking basics_see Links
On the left side of the "Home Page" is a list of items. One of which is
"LINKS". There is a FAQ site on basics of trunking. Could be some good info for you.
Again........good luck!
