BC796D and Motorola Astro
Deeke
Sudyal
Egypt
It's going to be real hard to program without the frequencies. You'll need to locate the frequencies or use the search function on the scanner. That is that whoever you want to listen to is not using encryption.
if i use the search i found some freq's but how i can know if it's a CC and other things
n8dhw
Middletown, Ohio
What exactly are you trying to program? The link you provided just takes you to the XTL5000 page on the Motorola website. That doesn't tell us what your trying to program into a 796D unless I'm missing something. Or if your just asking if the 796D can do Astro Digital like the XTL5000 then the answer is yes.
Sudyal
Egypt
What exactly are you trying to program? The link you provided just takes you to the XTL5000 page on the Motorola website. That doesn't tell us what your trying to program into a 796D unless I'm missing something. Or if your just asking if the 796D and do Astro Digital like the XTL5000 then the answer is yes.
sounds good ,, our police use that model ,, but if you dont know wich they use UHF or VHF and how to figure the CC channel and the other things
n8dhw
Middletown, Ohio
Well they don't necessarily have to be trunked they could be conventional unless you know for a fact they are trunked. In any case if you know nothing about there system then your best bet would be to start searching the bands. Or if you can get close enough to one while there transmitting you can grab the frequency that way. However doing it that way and if there trunked you will only have solved part of your problem. The other half would be finding the control channel for there system. However your location says your in Saudi Arabia so its anybodies guess in terms of what type of systems Motorola could have deployed over there. It could be a system that the 796D can't even track like a TETRA type system which are very common in other parts of the would outside the US.
Sudyal
Egypt
ok i did a search i found some bands but no sound but there trasnmision
so now if i wana make a search and write the bands on my note whats the best way
and must i trun the trunked on or not
thanks
torontokris
Toronto Canada
so you found nothing on any transmission?
try it again, keep scanning
you may be the first to find out the frequencies and can add them to the database.
Sudyal
Egypt
i found some freq's but i need to know if i wana search to Astro Motorola radios
what's the steps and if i wana trun the P-25 on something like that
thanks
Sudyal
Egypt
hi again
i got my antennacraft ST2 for my BC796D
8 meters from the ground still scanning but guys when i turn the turnk there four plans
when i choised the Plan 2 i saw on the screen the freq's and MOT ID: _ _ _ _ _
something wrong ?
need your help guys thanks
Sudyal
Egypt
guys if it's hard to help no problem i can pay for that if someone who can
thanks
