BC796D Priority Talkgroups Question/Problem
sjlamb
Sarasota County, FL
Owner's manual is fine on telling you how to designate a talkgroup as a "Priority Talkgroup" but says nothing about how to "undesignate" one and thereby remove its' "P" icon. I have a number of talkgroups within the same bank with the "P" icon showing next to the left of the talkgroup ID location and number while in "HOLD" mode: P M-6:16848
Can anyone advise on the secret to de-selecting a talkgroup from the Priority Talkgroups and thus, eliminate it's "P" icon?
Your help is greatly appreciated in advance.
scanner99
Los angeles
this is off topic but is the bc-796D digital or is it capable of scanning digital with a digital card
sjlamb
Sarasota County, FL
Yes... the BC796D is the predecessor of the BC996T and came standard with the APCO 25 digital card:
davidmc36
South East Ontario
I would try just doing the same thing that turned it on. It is very common for identical key presses to "toggle" things on and off.
sjlamb
Sarasota County, FL
Uhhhh..... well.... that's kinda why I posed the question. "Doing the same thing" doesn't turned them off or remove them.... and the manual is silent on the issue other than telling how to designate a "Priority Talkgroup"... nothing about removing that desination.
JoeyC
Senior Member
San Diego, CA
I believe each list has one Priority talkgroup - like it or not. Unless you select the talkgroup in another position, the default for each list is the TG in the first position. Thus 1-1, 2-1, 3-1 etc. You cannot de-activate the priority from the first position of each list (x-1) unless you assign the priority to another, i.e 2-2, 3-6, 4-0, etc.
If you choose to leave position x-1 empty, the P (priority) will remain on that talkgroup position.
Personally, I find little use for Priority in trunking as the 796 works, so I never used it.
sjlamb
Sarasota County, FL
Following your post; I now see where this is exactly how the Priority Talkgroups are configured. That being the case (with up to 100 Priority Talkgroups with all banks active), I also have to agree with your assessment that I would be best leaving the system Priority feature toggled "Off". Thanks for the explanation.
sjlamb
Sarasota County, FL
ps.... "your like it or not" observation is right on target.... Not Liking...lol
davidmc36
South East Ontario
Uhhhhh....well.......you did not say that you had tried that.
