BC796D talkgroup ID display
WpM
SD
Can the talkgroup ID be displayed when the scanner stops on a freq? I thought I saw them displayed once, but I might be mistaken.
DJ88
Brick Twp., New Jersey
They should display automatically. There are two scenarios:
1 - ID Scan Mode - You will hear transmissions for and see the Talk Group IDs displayed for the talk groups that you have programmed into your ID Lists for a particiular system.
2 - ID Search Mode - You will hear transmissions for and see ALL active Talk Group IDs in that system, regardless of whether you have them programmed into your ID lists or not.
I have a BC785D and I would assume that these functions work the same
on both mone and yours.
One more my unit does when it is in ID Scan Mode - When a talk group that I don't have programmed into my ID Lists becomes active, it stops and displays the TG ID for a split second, but no audio.
