BC796D: Bc796d
StoliRaz
Assigning a Text Tag
a. Use the scroll bar to select the channel you want to tag, then press E.
b. Use the scroll bar to select the letter, then press ▲/HOLD to move the entry position one space to the right or press LIMIT/▼ to move the entry position one space to the left.
c. When you have entered the tag, press E to save the tag. The scanner displays 1:OTHER CHANNEL Select to pick another channel to program from Step 1 2:CHANNEL OPTION Select to set additional channel options (see the following sections).
3 DONE Exit the channel setting and menu mode.
