BC800XLT Schematic
bonnema
I'm looking for a schematic for the BX800XLT made by Uniden shortly after they purchased Electra. It would help if there were reference voltages on the schematic.
The problem with my radio is that the display is very dim and I've replaced the capacitors to get the other voltages up to normal, but I suspect that the transformer that drives the display may be bad. Any thoughts?
wmbio
Cumberland, Md
Bc800
Maybe others will have a full schematic for you.
In my 40 years working on older Bearcat scanners here are my suggestions.
!. C98, install a 47 uf at 50 V. Goes bad 100% of the time
2. Your nixies may have just burnt out.from old age
Never seen the transformer be bad!
Good luck
Enjoy
Wmbio
bonnema
BC800XLT
I replaced the cap and one other to get the + and - voltages up to what they should be but the XFMR also puts out an AC voltage to the display and I don't know how much voltage that should be. I'd really like a schematic of the display/keyboard sub assy because hopefully that would have some voltages listed.
wmbio
Cumberland, Md
The secondary of the transformer has two windings,
The first provides 7.8 vac to the tripler for making the positive voltages of 23.6v at TP 6.and
Neg voltages 23.6V on one side of R107 and neg 18.0v on the other side of the same resistor..
The other secondary provides pos 12.6 VAC and neg 12.6 vac for the heaters of the nixie tubes
derevs
Capacitors generally have no effect on the voltage, that is the job of a resistor.
bonnema
BC800XLT
The AC voltage is what I needed to know. Thanks!
In this case, capacitors do make a difference as they are used to couple energy into the xfmr and to the tripler. Mine were both low in capacitance with the resultant low voltage output.
I'd still like to see a schematic of the display/keyboard sub-assembly
Thanks again for the respones.
