Ben96cal
Many of us in the San Francisco Bay area are absolutely fed up. We have had a new P25 Simulcast system in Oakland come online a few months ago and unless you are very close +- 5 miles the scanner is not decoding the traffic. You can have FULL bars but all you'll get a either zero traffic or you'll hear a bunch of jibberish. I've compressed the issue into this post from several posts of the thread going on in our forum.
BC's do NOT WORK with p25 simulcast unless you are line of sight with one site only, or close enough to one site that it over powers the other site and then your BC will pick up only that site and will not receive interference from the other sites.
This problem is caused by time delay of the signals your scanner is receiving from the multiple sites, it's like a simplex channel and 2 or 3 people try to transmit at the same time.
A simulcast system relies on VERY tight time synchronization and the mobiles are designed and programed to handle system time sync.
Unfortunately the reception problems with Uniden scanners are not caused by any temporary issues with the system itself. They are caused by the format of the digital signal. Uniden scanners were designed to decode C4FM modulation used on Motorola Smartnet and Smartzone systems. The new Oakland system uses CQPSK modulation, also known as Linear Simulcast Modulation (LSM), which is supposed to be compatible with C4FM, but the scanners do not handle it as well. As I mentioned before it is possible use a Uniden scanner to monitor the system if you are receiving a signal from only one site, but if you are in range of multiple transmitters, the multipath interference renders the scanner fairly useless.Sm example of this can be found in the below Youtube link.. This is not a new issue as MANY people have had the same issue back east and in the midwest on large state simulcast systems.
I've updated my 996 with firmware 1.06.
Youtube
P25 Simulcast Distortion - YouTube
The city of Oakland still has their Edacs system up and running and we all have zero issues with that system so it's not our setup.
Uniden please look into and resolve this issue asap. It's ridiculous that we bought a $500 scanner that isn't doing what it's supposed to on P25.
Youtube
