I recently purchased a 996P2 to go along with my 325P2. The 996P2 needs a firmware upgrade (1.10.01) so I fired up the BC_VUP3 upgrade tool but the 996P2 (and my 325 would not connect). The tool loads fine and it appears to find the port (sometimes) but shows that it can't connect 1/4 way through the process. I've used the BC_VUP3 tool in the past with no problems upgrading so it seems to be a recent issue with Uniden. I went into the Uniden info page https://info.uniden.com/twiki/bin/view/UnidenMan4/BCD325P2 to grab the driver and the page says directory not found. I went into the device manager to see if I still had the cable driver and its not listed. I'd like to upgrade to DMR/and NXDEN in the future but will the upgrade be needed to upgrade to DMR/NXDEN? I know my 3 computers connect with Proscan and Freescan because I was able to upload my programming to the scanners with no COMPort or connection issues with that process. I've adjusted baud rates, deleted and reloaded the tool etc with no luck. Thanks in advance for any solutions
