Is there a way to delete all the pre loaded systems all at once instead of one at a time?
W4KRR Member Premium Subscriber Joined Apr 1, 2001 Messages 3,710 Reaction score 297 Location Coconut Creek Oct 12, 2005 #1 Is there a way to delete all the pre loaded systems all at once instead of one at a time?
jpm Member Joined Dec 19, 2002 Messages 1,007 Reaction score 16 Oct 12, 2005 #2 What if you put your configeration in and having the clear scanner box checked.
Spec Member Premium Subscriber Joined Sep 9, 2003 Messages 740 Reaction score 1 Location South Carolina Oct 12, 2005 #3 Yes you can delete all the preloads at once. Check out the manual. There is a section that deals with that. Spec
W4KRR Member Premium Subscriber Joined Apr 1, 2001 Messages 3,710 Reaction score 297 Location Coconut Creek Oct 12, 2005 #4 jpm said: What if you put your configeration in and having the clear scanner box checked. Click to expand... I presume you mean by using the UASD software? I'll check that out. K
B b52hbuff Member Joined Dec 19, 2002 Messages 1,755 Reaction score 76 Oct 12, 2005 #5 W4KRR said: Is there a way to delete all the pre loaded systems all at once instead of one at a time? Click to expand... Press 2, 9, Hols while powering on the radio.
W4KRR Member Premium Subscriber Joined Apr 1, 2001 Messages 3,710 Reaction score 297 Location Coconut Creek Oct 12, 2005 #6 Spec said: Yes you can delete all the preloads at once. Check out the manual. There is a section that deals with that. Spec Click to expand... Page 81 tells you how to delete systems, one at a time, but I don't believe it tells you how to delete all of them at once. I don't believe it mentions the 2, 9, hold method either. No matter, I've got it now. Thanks to all.
jpm Member Joined Dec 19, 2002 Messages 1,007 Reaction score 16 Oct 12, 2005 #7 Coming to think about it you could do the 29 hold as well. dah i did that.
