jimyleg said:Not sure exactly what to say...
i recieve half transmissions clear and half garbled.
The scanner skips from dat to lnk to p25 during a transmission.
this happens quicky. so the tranmission is chopy and incomplete
jimyleg said:edcs
866.41250 866.91250 866.96250 867.26250 867.41250 867.61250* 867.86250 867.91250 868.41250
868.63750 868.88750
jpm said:There has also been reports on your location too. Only my 2 cents worth.
HillbillyUHF said:Yes he did mean EDACS!Haven't YOU ever made a TYPO before!
jimyleg said:I apologise, i mean APCO 25
This problem i am having is not edcs but apco 25 :shock:
It switches from lnk to dat to p25 rapidly on some transmissions causing garbled or chopping tranmissions. :?:
...the frequncys are saved in apco 25 format
Program it as a Motorola type II system. It's a 3600 baud APCO system (P16), not P25. (The giveaway is the "System Voice: APCO-25 Common Air Interface Exclusive" line in the database.)jimyleg said:Minnesota has a new system called "a.r.m.e.r" suposedly it's all apco 25.
800mhz standardjimyleg said:which one is motoroal type II?
Al42 said:Program it as a Motorola type II system. It's a 3600 baud APCO system (P16), not P25. (The giveaway is the "System Voice: APCO-25 Common Air Interface Exclusive" line in the database.)jimyleg said:Minnesota has a new system called "a.r.m.e.r" suposedly it's all apco 25.
Could be. The original problem sounds like a P16 system programmed as P25.Voyager said:Al42 said:Program it as a Motorola type II system. It's a 3600 baud APCO system (P16), not P25. (The giveaway is the "System Voice: APCO-25 Common Air Interface Exclusive" line in the database.)jimyleg said:Minnesota has a new system called "a.r.m.e.r" suposedly it's all apco 25.
Actually, the "System Type" is the giveaway.
BUT, it says it's a "System Type: Project 25 Standard" which means it IS P25. Is the RR database wrong?
Joe M.
