BCD 396XT in Texas
diamondbud
Must admit up front that I am fairly new to digital scanners and trunked systems. That being said I am trying to setup my Uniden BCD 396XT for a road trip from Arkansas to Houston. Setting up for the state of Arkansas did not seem to be a problem with their AWIN system, but I am at a loss for Texas. Is there no statewide or regional trunked system similar to the AWIN system? Any recommendations, suggestions would be appreciated. Again I am new to this hobby, so please keep it simple if you respond. Thanks for your help.
hiegtx
Dallas, TX
Hi Diamond
There is no "statewide" trunked system in Texas, though there are a couple of sizable regional systems. The system that you'll encounter the most, especially in the Houston Metro area, and much of East Texas (depending on your route) will be this one: Texas Wide Area Radio Network (TxWARN) Project 25 Trunking System, Various, Texas - Scanner Frequencies
Houston PD & FD are using a number of P25 Phase II talkgroups on that system, which your 396XT cannot monitor. However, you can still hear the essential portions of their traffic on Phase I TGID's. See this.
Looking at the TxWARN P25 system, the talkgroups labeled with a "D" in the Mode column are Phase I. Your 396XT will have no problem with those. This system, besides the Houston area, encompasses a number of counties along I-45 north, as well as other counties in East Texas. The only protion of the TRS using Phase II talkgroups (those labeled with a "T" in the Mode column) are in the immediate Houston metro area. The rest of them are digital, with some encrypted.
Another system you might wish to load, regardless of which route you plan to take, is that of TX DPS, the state troopers. Since you're a premium subscriber, you can import this via software, such as FreeSCAN, ARC-XT, or ProScan. Import the 'Statewide APCO-25 Channel Plan" frequencies and you'll have most all of what you need there.
In the Houston area, some agencies are still using the analog version of TxWARN, so you may want to import and load selected groups and sites from it as well.
If you can be more specific on which route you plan to take in Texas (I-30 to Dallas, then down I-45, or US 59 south from Texarkana, for example), then more specific recommendations could be made.
teufler
ST PETERS, MISSOURI
Here is a file that should get you from Arkansas to Houston. I'm guessing you are running down the eastern part of Texas . This is a Freescan 2.17 file. It is zipped so you can unzip with 7-zip or someother program .You have the whole state of Arkansas AKWIN, I have left the system to search for id's though I have included groups that will show up the text id incase id's that are stored show up. Houston is heavy with talk groups.
  • ARKANSAS HOUSTON.zip
teufler
ST PETERS, MISSOURI
First of all, I could have looked up your address and then I could see what route was the fastest from your home to Houston. The route goes thru the nw corner of Louisiana thru Shreveport so I have re-done the file. I hope this gets to you before you travel. WD0GSY
diamondbud
Great Help
Thanks for your help. It was way more than I expected and is perfect for what I needed. I appreciate you taking the time.
teufler
ST PETERS, MISSOURI
I am curious as to how the file I sent worked. It contained alot of systems and sites, probably too much but I did try to set quick keys. I left all of Arkansas under key 1, which I am finding a Troop in Missouri, seems to show up on other troops towers so having having them active, seemsd to improve me following transmissions.
